Axminster Workshop AW405FS Scroll Saw with Flexible Shaft
108360
From £129.98 £108.32
  5. Half Star
35 Reviews
  • 406mm throat allows larger projects
  • Includes Flexible Shaft and accessory kit
  • Variable speed for cutting various materials up to 50mm
If you are looking to purchase your first scroll saw, the Axminster Workshop AW405FS 405mm Scroll Saw is a great option. Ideal for many different scrolling projects, this scroll saw enables you to either drill a starting hole and make cuts inside a piece of wood, or cut from the outside and work your way inwards.
Buy with confidence
So sure are we of the quality of this scroll saw, we cover all parts and labour free of charge for three years! Find out more
Versatile with large capacity
The AW405FS offers a generous table size allowing for larger projects (410 x 254mm) with a 406mm (16") throat which tilts to 45° for bevel cutting.
Flexible Shaft
A flexible shaft and accessory kit is included; with grinding, polishing sanding accessories and more to take your work to the next level.
Variable Speed
The variable speed capacity allows you to utilise your machine for many different materials (max depth of cut 50mm).
Stable build
The base is crafted from heavy cast iron, ensuring minimal vibration for your projects.
Accepts a range of blades
The saw accepts both pinned and plain end blades. What's more, blade changing is simple thanks to a quick release tension knob.
Safeguard your health
Connect your scroll saw to a vacuum cleaner via the 35mm diameter dust port.
More than a Scroll Saw the AW405FS is a hobby station, including a flexible shaft and accessory kit. Fitted with a powerful DC motor, the AW405FS features variable speed for cutting a wide variety of materials up to 50mm thick. The blade arms are independently pivoted giving a virtually straight up and down action, giving a better quality cut.
A generous 406mm throat and tilting table offers plenty of scope and the saw accepts pinned or plain end blades. The clamps are easily accessible for blade changing. A blower helps keep the cutting line clean and easily seen and a 35mm diameter dust port allows the scroll saw to be connected to a vacuum cleaner. The heavy cast iron base gives stability and ensures low vibration.
A truly useful bonus is the power take off with a flexible shaft, for adding fine detail to your work. The accessory kit includes a generous assortment of sanding, polishing, cutting and grinding bits. Perfectly suited to this craft.
The AW405FS also comes with a blower nozzle, eye guards and service tools. This Scroll Saw is a perfect machine on which to begin a fascinating hobby.
Warranty Axminster Workshop 3 Year Guarantee
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
4.70 35
