Axminster Workshop Mini Bed Extension for AW355WL Lathe
110851
110851
- Suits the AW355WL Woodturning Lathe
- Extends the distance between the centres of your lathe to 740mm
- Achieve more capacity, without replacing your existing lathe
- Supplied with fixing bolts
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
Show more
Show less
An addition to the AW355WL Woodturning Lathe, this mini bed extension will extend the distance between the centres of your lathe from 510mm to 740mm. It can be bolted to the existing lathe bed for greater capacity without the need to extend your leg stand or workbench. This is an economical way of achieving more capacity, without replacing your existing lathe.
Supplied with fixing bolts.
EAN Barcode | 5052511133956 |
