Bosch AdvancedTrim 18V-8 Cordless Router 18V (Body Only)
- Supplied with 1/4", 6mm and 8mm collets
- Compact design and low weight, easy to handle
- Powerful maintenance free brushless motor
- Syneon Technology for optimum run time
- Compatible with Bosch 18V POWER FOR ALL batteries
Axcaliber A5 Foam Router Cutter PresenterSpecial Price £4.30 £3.58 was £13.58 £11.32 Save £9.28 £7.73
The Bosch cordless AdvancedTrimRouter 18V-8 is light and easy to use thanks to its compact design and low weight of only 1.1kg. This powerful cordless router offers efficient performance thanks to its powerful and maintenance free brushless motor.
To offer you a wide choice of potential cutters the router is supplied with three collets: 1/4", 6mm and 8mm.
The machine is fitted with Bosch’s intelligent Syneon Technology, which regulates the energy consumption ensuring you get the best performance out of the power available. It has a dust extraction adapter for connection to a suitable vacuum.
Note: this is a body only tool supplied without a battery or charger.
The good news is; it’s part of the POWER FOR ALL battery system from Bosch. It is compatible with the 18V batteries from any of the tools in the Bosch POWER FOR ALL FAMILY Home and Garden range.
Supplied With: 1/4”, 6mm and 8mm collets, Dust extraction adapter, Parallel guide fence and 3mm Round over bit.
This applies to all DIY power tools, garden tools or measuring tools from Bosch. This tool comes with a FREE two-year warranty, to extend your warranty to three years, simply log into MyBosch. and register your tool within four weeks of purchasing it.
Extended warranty includes: repair service, pick-up and returning your defective device for free. Warranty services are all provided by Bosch directly.
To register your tool, please visit MyBosch.Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 18 V |
Collets Supplied | 1/4", 6 mm and 8 mm |
Corded or Cordless | Cordless |
Cutter Speed | 10,000 - 30,000 rpm |
EAN Barcode | 4059952582443 |
Manufacturer Part Number | 06039D5000 |
Model | AdvancedTrim 18V-8 |
Nett Weight | 1.1 kg (without battery) |
Plunge Stroke | 38 mm |
Rating | Home Workshop |
Sound Pressure Level LpA [Uncertainty K] | 78 dB(A) [3.0 dB] |
Spindle Lock | Standard Feature |
Vibration Cutting Wood [Uncertainty K] | 1.0 m/s² [1.5 m/s²] |
