The Bosch SDS+ 'Multi drill' is an all-round 3 function drilling machine in the 4kg rotary hammer class and will drill very fast. It has a 900W motor that will deliver 5 joules of energy and is supplied in a kit form with a range of high quality accessories. This machine will drill in hammer mode (up to 90mm with tungsten core and 32mm in concrete), chisel with vibration kept to a minimum and drill without hammer made easy using the quick change chuck supplied. Features include a safety clutch to protect the user when drilling larger diameters, Bosch vibration control for longer working time and less fatigue, aluminium gear housing to give an extremely robust and durable casing and equal power in reverse mode as forward mode due to the patented rotating brush plate. Weighing 4.7kg it has good handling and control. Supplied in a case with a comprehensive range of accessories: Quick Change Chuck, 4 x SDS+ drill bits 10/12/14/16mm, Point & Flat Chisel, 4 piece Multi-Construction Set, Progressor Hole Saws 20/25/51mm, Hole Saw Adaptor, 6 self cut flat bits and side handle.
SDS+ 3 function 'Multi drill'
Delivers 5 joules of energy
Fast drilling 4kg hammer with a 900W industrial motor
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
