The GSB 18V-110 C is a top of the range, tough, no-nonsense combi drill. It is capable of drilling a 16mm hole in masonry and driving large construction screws. This powerful industrial rated tool has a maximum torque of 110Nm. To help handle this much power the GSB 18V-110 C has KickBack Control and an auxiliary handle. 5.0Ah Coolpack batteries, combined with its super efficient brushless motor ensure long runtimes, more holes drilled and more screws driven per battery charge. An integral LED light helps illuminate dimly lit work areas. Inbuilt battery protection against overload, overheating and deep discharge means you get the maximum life span out of this tool, with minimum fuss.
The GSB 18V-110 C is one of Bosch’s connectivity tools, with the capability to control various options and features within the tool through your smartphone. Fitting the optional GCY 30-4 connectivity module (sold separately) and using the free to download Bosch ToolBox App, allows you to manage each tool within the connectivity range via your smartphone.
Part of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
The GSB 18V-110 C comes with 2 x batteries (GBA 18V 5.0Ah), quick charger (GAL 18V-40 Professional), an auxiliary handle and an L-BOXX 136.
Note: Charger fitted with UK 3-pin plug.
Powerful industrial rated combi, max torque of 110Nm
5.0Ah means more holes drilled and more screws driven
Super efficient brushless motor with all metal chuck
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
