Bosch GSR 12V-15 FC FlexiClick Drill Driver Set 12V (2.0Ah)
103608
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
FlexiClick system provides a solution in tricky situations
4 interchangeable chuck options
Easy one click change
Compact design: only 132mm front to back
Integrated LED light for illuminating poorly lit places
Supplied with GFA 10mm capacity 3-jaw chuck, GHX hex bit holder, GWA right angle adaptor, GEA off-centre hex bit holder, 2 x 12V(2.0AH) batteries and L-BOXX 136 storage case
Whatever the task or situation, the Bosch GSR 12 V-15 FC FlexiClick drill driver with its 4 chucks is almost certain to have the solution. This 12V drill driver comes with 2 x 2.0Ah batteries, charger and L-BOXX 136 carry case. The kit also includes a GFA 10mm capacity 3-jaw chuck, a GHX hex bit holder, a GWA right angle adaptor and a GEA off-centre hex bit holder.
When it comes to driving screws in the tightest of spaces, the answer is only one click away. The Bosch Flexi-Click adaptors are easy and quick to fix on the tool body. You can rotate the adaptors to give the best possible working position. Neat and very compact, the GSR 12 V-15 FC will even take a 1/4" hex bit, directly in the drive shaft without an attachment, giving you the shortest option possible.
With this kit, you can easily perform tasks in compact and awkward spots such as driving screws and drilling in tight spaces or close to solid edges. There is even an LED job light for those poorly lit areas such as cupboard interiors.
N.B. Bosch Professional are changing the product name of 10.8V power tools, batteries and chargers to 12V. All Bosch Professional 12V tools are 100% compatible with all current (10.8V) Bosch Professional power tools, batteries and chargers. All 10.8V and 12V tools can be used within the same voltage class system.
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
