These three small gauges are beautifully made from solid hardwood with brass fittings. The stems are 150mm(6") long and the heads are approximately 50mm(2") square. Used for small or delicate work where a full sized standard tool would be too cumbersome. Choose from a marking gauge, cutting gauge or combination screw slide mortice/marking gauge.
Made from solid hardwood with brass fittings
150mm(6") long stems
50mm(2") square heads
Perfect for small or delicate work
Three available - marking gauge, cutting gauge or combination screw slide mortice/marking gauge
