Easy Wood Tools Full-Size Easy Turning™ Set 3-Piece
109209
From £379.98 £316.65
Low Stock
  • Ideal for spindles, table legs, large bowls, platters etc
  • No need to sharpen;, simply rotate cutter to a fresh edge
  • Solid carbide replaceable tips keep an edge many times longer than HSS
Customers Also Bought
Easy to turn. Easy to own.
100% Made in America
Easy Wood Tools were the first company to develop replaceable carbide-tipped turning tools for professional woodturners and hobbyists back in 2008. The company makes the tools in their headquarters in Kentucky and the carbide tips in their own manufacturing plant in Illinois. This gives them complete control over development and quality of their products.
What makes them 'Easy'?
Square section bar
This unique design ensures the tool sits flat and steady on the tool rest, making it safer and easier to use. No need to learn specific bevels or cutting angles to make your cuts, simply hold the tool and move it left or right to rough out, smooth or create coves or beads.
No need to sharpen
Each tool features a carbide cutter which keeps an edge at least ten times longer than HSS (High Speed Steel). When an edge eventually becomes dull, simply slacken the fixing screw, turn to a fresh edge and go again.
Pick your project
Easy Wood Tools offer a range of different size tools to ensure you have a tool perfect for your project. Within each range the tools have different coloured handles for quick and easy recognition.
Use these tools to turn dry or green wood; they equally work well on very hard woods, acrylics and resins. The negative rake tips work particularly well on acrylics, polyester and resins, and produce a smooth finish on timber.
Easy Wood Full-Size Easy Tools are ideal when it comes to turning spindles, table legs, large bowls and other similar projects. He longer handle offers greater control when working on larger projects
This 3-piece set comprises one of each tool:
The Easy Wood Full-Size Easy Rougher has a square cutter, it removes material quickly, cleanly and efficiently.
The Easy Wood Full-Size Easy Finisher with its round cutter, produces coves, hollows, sweeping curves and aids final shaping.
The Full-Size Easy Detailer helps create small coves, beads, and other fine details. It has a diamond shaped cutter.
The 406mm long handle is American Maple with a copper ferrule for strength (the tools have different coloured handles for easy recognition). The 12.7mm square section bar ensures the tool sits flat and steady on the tool rest. With the tool parallel to the floor and cutting at centre height the risk of catches and snatches is virtually eliminated. You don’t need to sharpen these tools. When an edge becomes dull you simply slacken the fixing screw and turn to a fresh edge. Easy Wood Tools’ carbide keeps an edge many, many times longer than HSS. These tools can be used to turn dry or green wood and acrylics.
Overall length of 622mm. The shaft is engraved with the corresponding carbide cutter reference number.
  • Use to turn dry or green wood, acrylics and resin
  • 8mm square section bar ensures the tool sits flat and steady
  • American Maple handle with copper ferrule for strength
    5.00 1
