This Faithfull Flap Wheel is most suited to sanding shaped and curved workpieces. Flexible and durable, the aluminium oxide flaps are secured with a resin bond to ensure extra strength and service life. The design ensures you will achieve a consistent finish, without the risk of clogging. The wheels have a built in 6mm arbor shaft, compatible with most power drills.
The course flap wheel is 60 grit. The medium flap wheel is 80 grit.
