At 555mm long the Faithfull No.7 Jointer plane does the job of truing long edges and flattening wide boards like no other plane. The length and heft make it unbeatable for these tasks. The long flat sole gives you a straight finish whether rough flattening or fine tuning an edge joint. This No.7 has a grey cast iron body for strength and stability with ground base and sides for flatness and squareness. The machined frog seatings eliminate blade chatter. The plane features fine depth and lateral adjustment. The lever cap has a brass locking screw for easy release when sharpening the blade. A wooden knob and tote complete the plane. Blade width 60mm.
Note: Faithfull planes represent excellent value for money. As such they may not be quite as refined as more expensive examples. A little work sharpening the blade and maybe some minor fettling will be most rewarding.
