FEIN AMM 700 MAX TOP AS MultiMaster AMPshare 18V (Body Only)
- Cut, saw, sand, rasp, scrape, polish, grind and more
- Kit includes 60 accessories
- AMPshare battery compatibility with Bosch 18V and others
Customers Also Bought
AMPShare is a multi-brand battery system offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Bosch Professional 18V tools and chargers all the way back to 2008.
The FEIN AMM 700 MAX TOP AS MultiMaster can cut, saw, sand, rasp, scrape, polish, grind and more. A vast range and variety of accessories allow you to perform tasks and access places other power tools cannot. This powerful professional machine offers outstanding performance under heavy work loads. This multi-tool takes the complete range of Starlock, Starlock Plus and Starlock Max accessories.The FEIN AMM 700 MAX TOP AS MultiMaster offers even more versatility thanks to the AMPshare battery compatibility.
This kit version comes with 60 accessories to get you started. Its brushless PowerDrive motor offers a long maintenance free service life. With variable speed and constant speed under load, you have complete control whatever the task or the material. Tool changes could not be quicker or easier with FEIN’s QuickIN system; three seconds is all it takes. The anti-vibration system provides long fatigue free working whilst noise insulation helps protect your hearing. This is a tough tool built to last with an all-metal gearbox. Electronic Cell Protection (ECP), protects the battery against overload, overheating and total discharge and an electronic safety cut-off protects you and the saw should the blade jam, for example.
Supplied with:
2 x E-Cut standard saw blades curved (35 mm)
2 x E-Cut standard saw blades curved (65 mm)
1 x E-Cut precision saw blade (35 mm)
1 x E-Cut precision saw blade (65 mm)
1 x E-Cut long-life saw blade (10 mm)
2 x E-Cut long-life saw blades (35 mm)
1 x E-Cut long-life saw blade (32 mm)
1 x E-Cut long-life saw blade (42 mm)
1 x E-Cut carbide Pro saw blade (32 mm)
1 x Segmented saw blade (Ø 85 mm)
1 x HSS segment saw blade
1 x HM rasp (triangular)
1 x Scraper blade
1 x Cutter blade, mushroom shaped
1 x Multi-function knife
1 x Sanding plate with holes
40 x Sanding sheets (10 of each grit 60, 80, 120 & 180)
1 x Dust extraction outlet
1 x L-Boxx 136 storage case
Note this is a body only tool supplied without batteries or charger.
- Powerful professional machine with outstanding performance
- Designed for continuous use with high workloads
- Brushless motor offers extended runtimes
- Constant electronic speed control with variable speed dial
- Takes all Starlock, Starlock Plus and Starlock Max accessories
