Festool DOMINO DF 500 Q-Set Jointer & Assortment 1060 - PACKAGE DEAL
- Unique 230V jointing system using DOMINO® shaped wooden dowels
- Patented routing principle with a wide range of adjustment options
- Stop positions for hole centres 16, 20, 22, 25, 28 and 40mm
Customers Also Bought
This package includes the DOMINO DF500Q-Set and the 1060 Assortment.
DOMINO DF500Q-Set
The 'DOMINO' is a unique jointing system using rounded loose tenons to join timber giving very strong accurate and precise joints. Combining exceptional versatility with simple handling for maximum precision, the DOMINO has a patented routing principle with a wide range of adjustment options to make it extremely easy to use. The machine's fence can be adjusted to cut slots centrally in 5 pre-set timber thicknesses and manually adjusted for other thicknesses. The dowels can be placed centrally, offset, in pairs or groups. There are retractable stops for accurate positioning from the edge of the workpiece. The jointer fence can be adjusted to 5 pre-set angles and is also infinitely variable between 0 and 90°. There are 6 different sizes of DOMINO available.
Various accessories increase the versatility of the DOMINO. The support bracket, which is a simple right angle bracket that attaches to the base of the DOMINO with two thumb screws, can be used to add surface area to the face of the DOMINO to increase stability during use. The trim stop will help align narrow wooden strips between 22 and 70mm centrally, plus it can be used for mitre cuts. The cross stop is used for repeat hole spacing between 100 and 205mm without the need for marking the work. Handrail fence and DF-stop for reducing the dowel centre from 37 to 20mm.
Supplied as a set version complete with D5 cutter, support bracket, trim stop, cross stop and Systainer T-LOC SYS3 187M case.
DOMINO Assortment 1060 in T-LOC SYS3 187M casee
An assortment of DOMINO beech wood dowels plus 4, 5, 6, 8 and 10mm cutters for the DF 500 DOMINO machine. Includes 1,060 DOMINO dowels in the following sizes altogether in a Systainer T-LOC SYS3 187M case: 4mm x 20mm, 5mm x 30mm, 6mm x 40mm, 8mm x 40mm, 8mm x 50mm and 10mm x 50mm.
- Depth stops at 12, 15, 20, 25 and 28mm
- Set version supplied with D5 cutter, support bracket and trim stop
- Cross stop and Systainer T-LOC SYS3 187M case
- DOMINO Assortment with 1,060 dowels
- 4, 5, 6, 8 and 10mm cutters
