Festool ETS 125 REQ-Plus Eccentric Orbit Sander
103071
From £410.98 £342.48
6 Reviews
Low Stock - Ready to dispatch
  • Fast results with a fine finish
  • Compact one-handed sander
  • Easy to use on vertical surfaces or overhead
  • MMC electronic control for constant speed under load
  • Plug-It cable system makes storage easy
  • Includes Longlife dust bag and edge PROTECTOR
  • Compatible with Cleantec extraction system
The Festool ETS 125 REQ 125mm compact eccentric sander is well balanced and easily manoeuvrable. At 1.2kg, it is light in weight and comfortable when used for sanding vertical or overhead surfaces with a single handed grip. The ETS 125 REQ features Festool’s MMC control electronics. The sander has a variable speed selector; the MMC control maintains the chosen speed under load. With all 250W of power in use, work proceeds at a rapid rate. The 2mm orbit and eccentric action leave an excellent surface finish in a short space of time. The ETS 125 REQ-PLUS includes a Longlife dust bag made from a durable polyester fleece. It is highly effective and easy to empty. Alternatively, you can connect to an extractor; the dust outlet is compatible with Festool’s Cleantec connection system. The PROTECTOR is an effective clip-on skirt around the sanding pad that eliminates the risk of damage when working against an adjacent vertical surface for example. Supplied with 125mm diameter StickFix sanding pad (soft-HT), edge PROTECTOR, Longlife chip collection bag and Systainer SYS 2 T-LOC case.
Benefits
  • Includes 36 month machine guarantee
  • Full repair, free of charge
  • Replaced in the event of theft
  • Original parts guaranteed
  • 14 day money back
5.00 6
