Festool Guide Rails
Festool Guide Rails
- Guide rail converts Festool circular saw and other machines into a system for cutting sheet materials
- Two embedded PTFE strips
- Two underside neoprene strips to reduce slippage
- Splinter strip cut by the saw blade on the first cut trimming exactly to cut line
- Clamps and joining bars available enabling two lengths to be accurately joined together
TSO Products Aligning Guide Rail Connectors GRC-12 (Pair)From £69.98 £58.32
Festool Guide Rail Green Slideway Lining 10mFrom £43.78 £36.48
Festool Rail Bag with Shoulder Strap For Rails up to 1,400mmFrom £79.88 £66.57
The combination of a Festool circular saw, jigsaw, router or insulation saw with the Festool Guide Rail creates a superb system for cutting sheet materials. The guide rails have two PTFE strips embedded into them to allow the tool to slide smoothly on the rail. On the underside of the rail there are two neoprene strips which hug the surface of the material, reducing slippage. There is also a special rubber strip on the underside which is used to minimise splintering on the top surface of the board. This strip is cut by the saw blade on the first cut and thereafter supports the upper face of the material whilst it is being cut.
Part of the Festool FS guide rail system.
Rating | Trade/Professional |
