Festool Jigsaw Blade Mixed Set Wood/Metal/Plastic (Pkt 21)
110697
From £86.98 £72.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Versatile 21-piece jigsaw blade set for wood, metal, and plastics
  • With five distinct blade types, you'll have the right tool for any job
  • Colour coding system makes finding the right blade easy
  • Comes in a reusable case
The perfect all-rounder kit, Festool's versatile 21-piece jigsaw blade set is perfect for tackling a wide range of materials including wood, metal, and plastics. With five distinct blade types, you'll have the right tool for any job.
5x Wood fine cut jigsaw blades S75/2.5 5/5
Fine-toothed blades suitable for softwood and hardwood, coated chipboard and veneered blockboard, soft plastics and acrylic plexiglas. Produces precisely cut and splinter-free surfaces; conically ground teeth for clean cuts. 75mmx2.54mm, cutting depth 55mm
5x Wood universal jigsaw blades S75/4 FSG/5
Universal blade for all relevant wood applications, HCS tool steel and cross-set teeth make it extra stable and very well suited for making straight, fast cuts. 75mmx4mm, cutting depth 30mm
5x Wood straight cut jigsaw blades S75/2.8/5
For highly precise cuts in wood materials. The HCS tool steel has extremely sharp Japanese teeth so wood fibres are firstly scored, then cut through cleanly. 75mmx2.8mm, cutting depth 30mm.
5x Metal steel/stainless steel jigsaw blades HS75/1.2 BI/5
High-temperature- resistant and wear-resistant. Rippled basic form made from HCS bimetal, this saw blade is ideal for processing aluminium, non-ferrous metals and steel. 75mmx1.2mm, cutting depth 20mm.
1x Plastics laminate jigsaw blade HM90/3.3
This blade has an extremely long service life. The high-temperature-resistant and wear-resistant carbide saw blade is particularly well suited to laminate and melamine resin boards. 90mmx3.3mm, cutting depth 30mm.
Finding the right blade is easy with Festool's color-coding system: yellow for wood, red for plastic, and blue for metal. Supplied in a reusable case.
