Festool MFK 700EQ/B Edge Trimmer Plus Version
- Very versatile router and trimmer
- Interchangeable router bases
- Ball bearing guide brake
Customers Also Bought
This is a very versatile tool with interchangeable bases and is specially designed for flush trimming and rounding of protruding edges. Its unique ball bearing guide brake ensures perfect, streak-free working results. The motor, being in the vertical position, allows for a wide range of hand routing functions, guiding the cutter where needed. With the extended trimming base fitted, the motor is now in a horizontal position. The bearing assembly then guides the cutter to give accurate trimming of solid edges and laminates, exerting pressure where needed. Extraction outlet fitted on the base for optimum extraction. The 720W motor has an electronic speed adjustment switch to ensure maximum power and speed selection depending on material and cutter. The motor also has a temperature monitor for long service life. This tool has a 27mm extraction outlet. Supplied as a PLUS version in a SYSTAINER® SYS Gen 3 187 case with the following accessories: 8mm collet, ball bearing brake and chip deflector.
- Simple easy guiding and handling in either mode
- Routing solid wood, acrylic, PVC edge veneer etc
- Motor temperature monitor for a long service life
- Electronic speed selector
- SYSTAINER® T-LOC case
