Festool OF 1010 REBQ-Plus Router (1/4")
- Extremely versatile and extremely precise
- Depth adjustment to within 0.1 mm
- Easy one-handed operation
Customers Also Bought
For power and accuracy, for easier, safer routing the Festool OF 1010 REBQ-Plus is in a class of its own. In a nutshell it is extremely versatile, excellently precise and very easy to handle.
The routing depth can be adjusted to the nearest tenth of a millimetre in seconds. The double-sided column clamp makes the router extremely torsionally rigid, guaranteeing perfect routing results. The clever design gives you a clear view of the router cutter ensuring better results.
This router allows easy one handed operation either with the Festool guide rail system or freehand. Its unique (27/36mm connection) chip deflector when combined with a suitable extractor ensures dust extraction is extremely efficient.
Festool's Plug-It system with its detachable power cable enables the fast swapping of Festool tools or easy cable replacement.
Supplied with 8mm and 1/4" collets, side fence, guide rail adapter, chip deflector, open ended spanner all packed in a Systainer SYS3 M 237 case.
