Fuji Spray Q4 Platinum Turbine Unit & T75G Gravity Spray Gun
717484
From £1,369.97 £1,141.64
In Stock
  • Fuji Spray Q4 Platinum Turbine Unit
  • Quiet running advanced four stage turbine power unit
  • Heat Dissipation Box results in much cooler running
Customers Also Bought
Package deal comprises the Fuji Spray Q4 Platinum Turbine Unit and the T75 Gravity Spray Gun.
The Fuji Spray Q4 Platinum system is an upgraded version of the Gold Pro. It consists of a powerful four stage turbine power unit fitted with Fuji's unique quiet technology like the Gold, but now also incorporates the Fuji Heat Dissipation Box (HDB) found on the top of the range platinum models. The HDB expels excess heat from the turbine resulting in much cooler operating temperatures and longer motor life. Because the air delivery pressure is low, an excellent finish can be achieved without the mess and wastage which usually results from excessive overspray. Most finishes can be sprayed, including inks, stains, lacquers, varnishes, enamels, acrylics and so on, although some will have to be thinned before use. Included with the unit is Fuji's very comprehensive guide which covers all aspects of HVLP spraying in great detail and 7.6m(25') of 3/4" bore hose.
Fuji Spray T75 Spray Gun
The Fuji Spray T-Series Spray Gun features an exclusive side-mounted pattern control knob to adjust the size of the fan. This knob allows you to switch from a small to large pattern or anywhere in between. Unlike HVLP turbine spray guns with the front collar adjustment, the pattern control knob offers full incremental fan size throughout the whole range.The fan pattern is adjustable from 1" to 15" from a distance of 8". Smaller than 1" is achieved by moving closer to the object to be sprayed. All T-Series Spray Guns are installed with a 1.3mm needle and nozzle set-up. You can obtain a professional finish with all known coatings. The gun body is CNC machined to aircraft tolerances. All Fuji spray guns are non-bleed. Air passes through the spray gun only when the trigger is pulled. The light weight of the T-Series and easy-pull trigger means less fatigue for the operator. The T-75 Gravity Gun is assembled with a 600cc Nylon Cup, which provides a perfect seal, with no gasket required.
  • 7.6m(25') of 3/4" bore hose
  • Low delivery pressure gives good finish with reduced overspray
  • Most finishes can be sprayed including inks, stains, lacquers, varnishes, enamels and acrylics
  • Included is Fuji's very comprehensive guide covering all aspects of HVLP spraying in great detail
  • Fuji Spray T75 Spray Guns
  • Non-bleed design, air only passes through when trigger is pulled
  • Side mounted spray pattern control knob allows continuous adjustment
  • Centre mounted 600cc nylon gravity cup
  • A stay-cool nylon handle (fitted over a metal tube)
  • Stainless steel fluid passages and external needle packing adjustment
  • Metal fluid knob and collar, stainless steel internal components
  • Rear rotating nipple for pressure tubes, easier use for the left-handed
Warranty 2 Year Warranty
    4.70 3
