GripIt TV Kit
106506
GripIt TV Kit
106506
- TV Kit for fixing TV securely to plasterboard wall
- 4 x Gripit Blue plasterboard fixings, 1 x 25mm Gripit flat bit
- 4 x locking washers, flat washers and M8 x 20mm bolts
Show more
Show less
Gripit is a unique method of fixing an item to a plasterboard wall. Gripit fixings distribute the load over a much wider area compared to conventional fixings or plugs. Gripit is one of the strongest plasterboard fixings available.
The Gripit TV Kit contains 4 x Gripit Blue plasterboard fixings, 4 x locking washers, four flat washers, 4 x M8 x 20mm bolts and a 25mm Gripit flat bit. Using these heavy duty Gripit Bluefixings, you can be assured that your smart TV is secure.
N.B. These fixings are not suitable for cantilever bracket installations.
#AxminsterTools
