Heavy Duty Polishing Kit for Wood
503939
From £34.98 £29.15
1 Review
  • Use with a drill, flexible shaft or bench grinder fitted with a taper spindle
  • Produce a high gloss finish wood (hard or soft)
  • 2 x mops, 1 x bar of compound, 1 x pigtail arbor with 6mm shank
Used with a power drill or flexible shaft, this kit provides all you need to produce a high gloss finish on wood, hard and soft. It only takes two easy steps, initially with the 100mm x 4 section aluminium oxide abrasive lap, followed by the 100mm x 2 section stitched mop and buff compound. The kit also includes a pigtail arbor with a 6mm shank with which to mount the mops in a drill chuck.
4.00 1
