JSP Force™10 Typhoon™ Full Face Mask With Visor
- Full face mask combines respiratory and face protection
- Padded for extra comfort over prolonged use
- Fully adjustable 5-point suspension harness
- Panoramic anti-mist, anti-scratch with impact protection
- Typhoon valve breathe comfortably without fatigue
- Filters available with low profile angle design
- Order filters separately, dependent on required usage
- EN140 optical class 1 EN166 B (impact) EN 136 (class 3)
The JSP Force™10 Typhoon™ is a lightweight, easily maintained full face mask with a panoramic visor and Class 3 heavy-duty filter connections.
Using extensive independent research into human face shapes, JSP has been able to refine the design for a comfortable fit with an effective face seal. Made from a durable thermoplastic rubber, the mask will fit most face shapes. The 5-point suspension harness and quick release buckles make it easy to adjust. The mask moulds to the shape of the face and padding provides extra comfort. It is available in 2 sizes (M or L).
The optical Class 1 visor conforms to EN166.B impact protection (tested with a 6mm steel ball bearing travelling at 270mph). The completely clear panoramic visor maximises light levels within the mask giving optimum visibility. The visor has anti-mist and anti-scratch coating as standard and comes complete with a replaceable peel-off visor protector.
The unique Typhoon™ valve has very low breathing resistance, which in turn reduces heat and moisture build-up within the mask. The Typhoon™ valve allows you to breathe comfortably without fatigue.
The Force™10 Typhoon™ is compatible with both JSP Classic filters and PressToCheck™ filters. Using PressToCheck™ filters allows you to check that you have the correct seal every time. The Force™ 10 offers flexibility for many applications, providing protection against particulates, many gases and vapours.
Disassembly, cleaning and maintenance are effortless with replacement parts available if necessary. JSP Force 10 respirators are reusable. For convenience, they can be easily stripped, cleaned, maintained and reused for an indefinite period of time. Replacement filters whilst not indefinite, last far longer than single use disposable respirators. JSP recommend 1-3 days for high use, 3-5 days for medium use and 28 days maximum for light use.
Conforms to EN140 optical class 1 EN166 B (impact) EN 136 (class 3)
An initial face fit test is recommended.
