This medium JSP Force™ 8 Twin Cartridge Half-Mask comes with two PressToCheck™ P3 high efficiency particulate dust filters. The Force™ 8 PressToCheck™ filters allow you to instantly check that you have the correct seal every time. The Force™ 8 features the Typhoon™ valve, which has very low breathing resistance, allowing you to breathe comfortably without fatigue.
Made from a durable thermoplastic rubber, the mask is comfortable and offers a superior fit to most face shapes. The carefully designed 4-point suspension harness has quick release buckles. The mask accepts the full range of low profile Force™ 8 filters. This gives the Force™ 8 the flexibility to be used for many applications, providing filtering protection against particulates, many gases and vapours.
JSP Force 8 respirators are reusable; they can be easily stripped, cleaned, maintained and reused for an indefinite period of time. Replacement filters whilst not indefinite, last far longer than single use disposable respirators. JSP recommend 1-3 days for high use, 3-5 days for medium use and 28 days maximum for light use.
Conforms to EN140.
For a useful cleaning guide, please refer to the Downloads section
JSP Force™ 8 Half-Mask with PressToCheck™ P3 Filters
Filters allow you to check that you have the correct seal every time
Comfortable thermoplastic rubber mask offers superior fit
Low resistance exhalation valve for easy, fatigue free breathing
Fully adjustable 4-point cradle suspension ensuring an effective facial fit
Reflective strips create increased visibility in low-light environments
Accepts the full range of low profile Force™ 8 filters
Conforms to EN140 (face piece), EN143:2000 (filter)
