Lamello Clamex S-18 Connectors
- Clamex S-18 - the innovative biscuit-shaped connector from Lamello
- Aligns and connects, 2 functions in one
- Maximum aesthetics due to minimal hole size for opening and closing of the connection
- No torsional movement due to aligning pins
- Many angles possible
- Stackable, since no parts protruding from the surface
- Easy installation with any Lamello biscuit joiner
- Usable in solid wood and wood composites
- Tolerance lateral ± 0,5 mm (max.± 0,75 mm)
- Made of fibre-glass reinforced plastic
- Knock down furniture connectors
- Show More
Aligning, connecting and detachable the Clamex S-18 connector is very clever, no need for glue and only a small 6mm hole visible on the whole joint the Clamex system is a great way to joint. Cabinet makers, joiners, carpenters, interior fitters, shop and exhibition fitters and people in the furniture industry would all benefit from using Clamex. These are repeatable, detachable connections without noticeable wear. When on site there is minimal assembly time with full prefabrication possible. It is stackable with no protruding parts on the surface and is easy and efficient to install. There are no additional positioning parts such as dowels or tongues required. Tolerance lateral ± 0,5 mm (max.± 0,75 mm) No torsional movement due to aligning studs.
Made of fibre-glass reinforced plastic with a zinc die-cast alloy lever. Size 66 x 29 x 9mm. Groove can be cut with your biscuit jointer fitted with the Clamex HW blade.
EAN Barcode | 7640129663606 |
Pack Quantity | 18 |
