Lamello S-20 Drill & Alignment Jig
109898
109898
- Jig to be used as an alignment tool for the joint
- Can be used on the inner and outer side of the workpiece
- Works well for 90° and 45° angles
- Used to drill 6mm holes required for access to locking mechanism
- For Lamello Clamex S joints
- Drill jig is in a fixed position
Lamello Biscuits - 100 Mixed (50 x 20s, 30 x 10s & 20 x 0s)From £9.98 £8.32
Show more
Show less
This drill jig is an alignment tool for the Clamex S-20 connectors, that can be applied on both the inner and outer sides of a workpiece. It allows for the drilling of 6mm holes that are required to lock the mechanism in place and allows for precise placement of the connector. Working especially well on 90 and 45 degree angles, this drill jig is in a fixed position. (Note: the jig is supplied with no drill bit and no S-20 connectors).
EAN Barcode | 7640348848235 |
