Lamello Zeta P2 Biscuit Jointer HW in Systainer Case
- Upgraded Zeta with a P-System depth adjuster
- Unique dual function biscuit jointer
- Produces special 'T' slot for Clamex P joiners
- Can also be used as standard biscuit jointer
- Clamex P fitting is almost totally concealed
- Clamping fitting that overcomes many design problems
- Clamex 7mm blade, assorted fittings, drill bit, drill stop collar, drill guide, suction adaptor
- Supplied in Systainer case
The ultimate jointing solution
Create strong and accurate joints effortlessly with this versatile biscuit jointer. With a whole range of different connector types, the Lamello Zeta system can overcome many design jointing challenges. Available as a corded or cordless machine; the cordless model is part of the 18V CAS system, allowing you to interchange 18V batteries with over 30 European manufacturers.
Precision
A unique feature to Lamello, the Zeta P2 jointer has a special vertical mechanical drive (VMD). Engaging when the jointer is at full plunge, it moves the cutter up and down in one full turn and only then disengaging to produce the ‘T’ slot, to accept the connectors. This means no glue or screws are required to hold the connector in place.
Almost invisible joints
Create precise and tight biscuit joints with the Zeta P2. With its micro-adjustment feature that ensures accurate joints for any project, you can secure any woodworking joint with ease without the need for clamping. Creating almost completely concealed joints, your workpiece will look seamless and flush.
Versatile
Expand your possibilities with Lamello’s unique connector system. Being self-clamping, it requires no additional clamping to create endless joint types and angles. Achieve the desired joint that your project requires, by easily sliding in the connectors either side of the joint, without the need for glue. Some of the connectors can also be dismantled and reconnected, making for easy transportation and assembly of projects.
User friendly
The Zeta overcomes lots of design issues and is extremely easy to use, thanks to its intuitive design and user- friendly features. Quickly change the cutting depth, adjust the fence angle and make accurate cuts and joints, in no time at all.
Stands the test of time
Founded in 1944, Lamello has a tradition of innovation. Making notable improvements and radical solutions in woodworking, Lamello is prominent in the industry. As the inventors of the biscuit jointer, the family name Lamello remains synonymous with bringing high-quality jointing solutions to people around the world.
Connector types
With such a comprehensive range of different connector types, Lamello is never short of clamping opportunities. The Clamex and Flexus connectors are self-clamping and disconnectable, with only a 6mm hole visible on the joint. Bisco biscuits are used to align and are held in the groove due to its surface structure. Divario is a self-clamping, sliding connector which is totally invisible. Lastly, Tenso is self-locking, self-clamping and totally invisible, although cannot be dismantled. There truly is a connector for every joint.
Book your demonstration
Lamello products are renowned for their precision and quality, saving you time and money with outstanding results. Our knowledgeable and friendly team are available to demonstrate the Lamello range in person or via a video call. You can see the tools in use and ask questions before placing your order.
Request a visit or video call
Lamello P-System Professional Connector Assortment In Sortainer CaseFrom £699.98 £583.32
The Zeta P2 is the second generation Zeta fitted with the new P-system depth adjuster. The Zeta offers more than the standard biscuit jointer, with an undercut function to allow for the fitting of special concealed Clamex P connectors that slide into the 'T' slot produced. The connector also clamps, so no additional clamping methods are required. Almost totally concealed, the only visible sign is a single 6mm hole, making it ideal for many applications such as furniture, shop fitting and exhibitions. It is also suitable for solid wood and man-made boards, overcoming many design issues.
Unique to Lamello, the jointer has a special vertical mechanical drive (VMD) engaging when the jointer is at full plunge, moving the cutter up and down in one full turn and only then disengaging to produce the 'T' slot to accept the special Clamex biscuit. The undercut function can be switched off and a 7mm slot will be produced; a 'Bisco' biscuit can then be used. Replace the special blade with a 4mm biscuit blade and use as a standard biscuit jointer. The new P-System depth adjuster has five settings for the ever growing range of Clamex connectors and when used with a standard biscuit jointing blade.
As with all Lamello products, design and build are of the highest quality. Other features include precise plunge with clear depth setting and jointer fences with flush sides to make positioning simple; the fence fits with 'V' grooves for accuracy and clear angle scale.
The jointer is supplied in a Systainer case with a special 7mm blade, assorted fittings, drill bit, drill stop collar, drill guide and suction adaptor.
Lamello Trade 3 Year Guarantee
3 years' extended guarantee exclusively on this Lamello Biscuit Joiner. Product must be registered on the Lamello website within 30 days of purchase. Applies to selected countries.
A 2 year warranty applies to all Lamello devices; no registration required.
Blade Diameter | 100 mm |
Bore Size | 22 mm |
Corded or Cordless | Corded |
Cutter Speed | 9,000 rpm |
EAN Barcode | 7640149931297 |
Model | Zeta |
Motor Power | 1,150 W |
Nett Weight | 3.7 kg |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 92 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 81 dB(A) [3.0 dB] |
Tilting Base | Standard Feature |
Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
Voltage | 230 V |
