This Saw and Guide Rail Kit combine to give you the potential to make perfectly accurate straight cuts up to 3.2m long. The Guide Rail Kit comprises 2x 1600mm Guide Rails (F 160), 1x Joining bar (F-VS), pair of quick action guide rail clamps and 1x Carry/Storage bag
The MT 55 cc excels as a plunge cutting circular saw whether on or off the guide rail. The powerful CUprex-Compact motor and continuously variable speed allows for a variety of blade options for cutting different thicknesses and different materials. Blade changes on the MT 55 cc are fast and simple. This all-round machine has some unique features; a tracking pointer moves when tilting the blade to indicate the exact position of the cut line at any angle. The scoring function enables you to produce a perfect finish in any material. A -1° undercut facility is great for perfect butt joints (the full tilt range is -1° to +48°). The well positioned depth stop is fully adjustable to within a millimetre and adjustable for blade wear after sharpening. Everything a plunge saw should be.
The MT55 saw is supplied with a 48T saw blade and Mafell T-MAX case, the Guide Rail Kit consists of 2x 1600mm Guide Rails (F 160), 1x Joining bar (F-VS), pair of quick action guide rail clamps and 1x Carry/Storage bag
