The DJR187Z cordless sabre or reciprocating saw features a Makita high efficiency brushless motor. Brushless motors are virtually maintenance free. They are far more efficient than a brushed DC motor. As there is no brush to cause friction against the motor, your battery saves power giving you a run time up to twice as long. A vertical crank design ensures high cutting performance and greater durability. The DJR187Z has electronic 2-speed selection as well as a variable speed trigger control. Tool-less blade changing means an end to hunting around for the right hex key. The soft grip handle with an anti-slip elastomer wrap offers comfort and helps minimise vibration. With the wide variety of available blade types, you can cut wood, metal and plastic. This version is body only and requires power from a Makita slide-on LXT 18V Li-ion battery.
Multi-purpose, multi-cutting saw for wood, metal, plastic etc
Fitted with brushless motor: extends battery runtime
High efficiency crank mechanism
Tool-less blade change, simple locking mechanism
2 speed electronic speed selection with variable speed trigger switch
Maximum cut in wood of 255mm
Ergonomically designed handle: for safe and comfortable grip
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
