Makita TM3000CX4 Multi-Tool with 57 Accessories
- More like a total tool kit in one tool, just change the accessory
- Cut, sand, rasp, scrape, polish and more, host of accessories available
- Smooth oscillation action, select speed depending on the task
Customers Also Bought
Like a total multi-tool kit in one tool, cut, sand, rasp, scrape, polish and more, just change the accessory and, with a host of different accessories available, you will be sure to find the one to suit your task. Smooth running with an oscillation action, you can vary the speed with the control dial depending on the task, accessories can be fitted in a full 360° range at 30° increments which allows you to get into very awkward places and are locked in place with a hex bolt.
Makita tools accept oscillating interface system accessories (OIS) such as Fein (star fitting) and Bosch.
Supplied with dust extraction attachment, sanding pad, 50 sanding sheets mixed grits, 85mm blade for wood and metal, 3 x 10mm blades for wood, 1 x 28mm wood and metal blade, universal blade adaptor and strong storage case
- Accessories can be fitted in a full 360° range at 30° increments
- Makita tools accept OIS interface system accessories, Fein (star), Bosch and Imperial
- Supplied with dust extraction attachment, sanding pad, 50 sanding sheets mixed grits, 85mm blade for wood and metal, 3 x 10mm blades for wood, 1 x 28mm wood and metal blade, universal blade adaptor and strong storage case
