The pointed pad of Delta sanders gives them easy access into corners and tight spots. The DEOS 663CV takes things further with a compact low profile body and light weight, the perfect sanding solution even for an extended period.
When it comes to those tight spots the DEOS 663CV is unrivalled. It makes sanding jobs faster, easier and more comfortable than ever before, especially when working on vertical areas. The 3mm orbit diameter and powerful brushless motor makes it the perfect tool for effective and fast stock removal. The low weight and exceptionally low vibration levels allow prolonged use without the prospect of aching muscles and tired shoulders. You can monitor vibration levels, in real-time with a Bluetooth connection to the myMirka app.
The use of Mirka's Abranet net abrasive and direct connection to a suitable extractor offers virtual dust-free sanding and minimal time spent cleaning up.
The 663CV delta sander comes with a Mirka Deco Solutions kit containing 50 Abranet sheets P80, 50 Abranet sheets P120, 100 Abranet sheets P180 and a pair of Mirka safety specs.
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
