The DEROS 350CV is unique; with a compact body, 77mm disc and low weight (only 0.8kg) it is the perfect small sander. In the DEROS 350CV, you have a low profile, easily manoeuvrable sander, with efficient extraction and minimal vibration levels. This 77mm sander with its user-friendly, compact body reaches small areas a regular sander cannot reach. The design makes it perfect for tackling small repairs, hard-to-reach areas, furniture restoration, painting prep, auto body dent and scratch repair and more. No more tired arms and wrists caused by holding a heavy awkward sander when sanding tricky areas.
The body of the machine houses a 250W brushless motor with soft start and electronic pad brake for controlled sanding. The variable speed has a range covering 4,000 to 10,000rpm, while the 5mm oscillation offers high stock removal rates.
It has the lowest vibration values in its class. You can monitor vibration levels in real-time with the myMirka app.
The Deco kit which comes with the DEROS 350V includes 50 Abranet Ace discs P80, 50 discs P120, 50 discs P180.
2+1 Extended Warranty for Mirka sanders, registration required within 30 days.
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
