Mirka Edge Protector for Pad DEROS 150mm Sander
108785
108785
- Simply clips onto the DEROS 150mm
- Protects the vertical face when sanding into a corner
- Prevents scratching or damage
- Protects the edge of the DEROS’ pad from damage
- Doesn’t interfere with the performance
- Easily removed when not required
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)From ÂŁ29.98 ÂŁ24.98
Axminster Professional Forged Flat Bar Clamp 200 x 80mmFrom ÂŁ15.58 ÂŁ12.98
Show more
Show less
This really is a win-win situation. The Mirka Edge Protector simply clips onto the DEROS 150mm. When sanding into a corner it protects the vertical face of the work preventing scratching or damage. At the same time it protects the edge of the DEROS’ pad from damage from contact with the vertical face. The Edge Protector doesn’t interfere with the performance or efficiency of the DEROS. It is easily removed when not required. Win-win.
EAN Barcode | 6416868557749 |
