The Mirka ROS650DB is a 150mm air powered random orbital sander with a 5.0mm orbit. It is fitted with a central vacuum port and dust bag system which ensure completely dust free sanding without requiring connection to an extraction system. This sander is extremely light in weight, very well balanced and can be used for long periods. The speed can be regulated through a range of 4-12,000rpm. Suitable for use on all kinds of surfaces and capable of a very fine finish. A great sander for work surfaces, large furniture and vehicle use. 2+1 Extended warranty on Mirka sanders, registration required within 30 days. The tool is supplied with a 1/4" BSP female thread for air hose fitting.
Smooth, light and powerful 150mm pneumatic random orbit sander
Fitted with the central vacuum port and collection bag for dust free sanding
5.0mm orbit, suitable for use on all types of surface
Speeds can be regulated between 4,000 to 12,000rpm
2+1 Extended warranty on sanders, registration required
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
