From £119.98 £99.98
Low Stock
  • Self-clamping, invisible connection for 90° and 45° joints
  • Pulls parts together from the inside, produces incredibly strong joints
  • Joints can be taken apart and reassembled many times without loss of strength
Customers Also Bought
An innovative solution to cabinet making
An affordable alternative to other jointing systems on the market, this package will help you become more efficient at work, saving you time and money.
Versatile
The Peanut® 2 Mini Jig is now available with either a 1/2" or 8mm shank, making it suitable for a wider range of applications than ever before.
Easy to use
The Peanut® 2 Mini Jigs are so easy to use, they can be learned in minutes. Instructions are included and there are plenty of videos and extra resources on both the Axminster and Intelligent Fixings websites.
Portable
The compact design of the Peanut® 2 Mini Jigs, means they can be used in your home workshop or on site and are supplied with a handy carry bag for easy transportation.
Strong
Joints created using the Peanut® Mini Jigs are guaranteed to be extremely strong at both 45 and 90 degrees. They will be able to withstand multiple disassemblies and assemblies with no loss of strength to the joint.
Fast
The Peanut® Jigs are a speedy solution to your everyday joints, thanks to the unique connectors. As the material is pulled together from the inside, there is no need for clamps and therefore no waiting around for glue to dry whilst assembling.
Invisible
The compatible connectors for this jig clamp and pull the material together from the inside, meaning your joints are always invisible and your workpiece looks tidy.
Tailor to your project
The Peanut® 2 Mini Jigs are compatible with three different invisible connecting systems - Peanuts®, loose tenons and dowels, meaning you can choose which suits your project best.
The Peanut Mini Jig is the ultimate jig for hidden connectors. The jig allows woodworkers to take advantage of 3 invisible connector systems; the Peanut 2 System, DOMINOs and dowels. Each system can be used for 90° and 45° connections.
The Peanut 2 and Peanut 2 Short connectors are incredibly strong and completely invisible fixings which clamps and pulls the material together from the inside. The Peanut 2 is perfect for 90° joints and the Peanut 2 Short allows for 45° and face-to-face connections.
The Peanut Mini Jig is portable and easy to use, making it the perfect jig for on-site or in the workshop. No special bench is required, you just need a 1/2" or 1/4" (using an 8mm collet) router with a standard 30mm guide bush and good quality clamps.
The Peanut Mini Jig includes features that enhance its versatility:
1/ Large clamping zones for faster clamping and the use of larger clamps.
2/ Easy tool set up for small routers: the jig shape allows the router cutter depth to be easily set on small routers.
3/ Mid-panel routing; the jig can be secured to the workpiece for mid-panel routing by using short screws in countersunk screw holes on the jig body.
4/ DOMINO connectors and dowels at 90° and 45°; DOMINO slots can be routed and drill bushes are available for 5mm, 6mm, 8mm and 10mm dowels. The fence has two fixing positions allowing for both 90° and 45° routing.
5/ Horizontal and Vertical centre lines inscribed onto the jig body; vertical centre lines for placing DOMINO connectors. Horizontal line which helps centre on the router cutter.
Create secure, strong joints, which can be taken apart and reassembled many times without loss of joint strength, ideal for flat-packing for transportation.
3.5mm gauge screws are required with the length of screw, depending on material thickness.
Recommended material thickness:
90° - 15.3mm plus
45° - 18mm plus
Contents:
1x Mini PEANUT® Jig body
1x Jig fence
2x Gravity stopping studs
1x Drill guide bush (6mm)
2x M6 Allen bolts
2x Allen keys
1x 6mm drill bit with stop collar
1x Case for jig
1x Small drawstring cotton bag for accessories
Note: The Peanut Mini Jig requires a standard 30mm guide bush that protrudes no more than 9mm from the base of the router.
    4.30 3
