PROXXON SP/E Grinding & Polishing Machine
474739
From £106.98 £89.15
3 Reviews
In Stock - Ready to dispatch
  • Electronic speed control from 3,000 to 9,000 rpm
  • Slim housing helps when grinding long workpieces
  • Adjustable tool rests and eye guards, includes adaptor to connect to a vacuum
  • Spindle lock for easy changing of wheels and discs
  • Supplied with 50 x 13mm corundum (grade N) and silicon carbide (soft compound) discs
With electronic speed control from 3,000 to 9,000 rpm or 8 to 24m/sec with standard wheels. The slim housing facilitates the grinding of long workpieces and includes an adaptor to connect a vacuum cleaner to the unit. The tool rests and eye guards are both adjustable. A spindle lock eases the changing of wheels and discs. Supplied with a 50mm x 13mm corundum (grade N) and silicon carbide (soft compound) disc for general grinding and sharpening of hard materials respectively. The right hand drive accepts the polishing arbor supplied as standard. Wheels 50 x 13 x 12.7mm. Motor 230V. Insulated to class 2.
5.00 3
