A No. 62 low angle jack plane, was first produced in the dim and distant past by Stanley, It was originally intended for use on end grain and stock removal. The Stanley version had its faults though, namely the thin casting. Modern casting methods and design means the Rider No. 62 will bring you only positive results. The bed angle (12°), bevel-up blade, depth adjustment and adjustable mouth are all features reminiscent of superior block planes. The No. 62 performs exceptionally well when used on a shooting board. The 12° bed combined with a bevel angle of 25° gives you an effective cutting angle of 37°. The chunky blade is 5 mm thick and able to slice through timber with ease without fear of chatter. The micro depth adjuster combined with an adjustable mouth gives you complete control to produce the thinnest of shavings and leave the silkiest of surfaces. One of the key features the No. 62 has over other bench planes is the easily adjustable mouth, meaning timber tear can be kept to a minimum.
The main casting is a ductile iron alloy, chosen for its high strength and its impact and high corrosion resistant properties. The cap iron and other quality fittings on the planes are solid brass, an ideal material for moving parts. The sole is 350 mm (14") long with a 50 mm (2") wide, 4mm thick blade. The sole of the plane is flat and accurate. Weight 2.24kg (4lbs 15oz).
Rider planes only require the bare minimum of preparation. Each blade is oil quenched, high carbon steel, hardened and tempered to HRC 63. We are confident that Rider planes represent a good standard of traditional, quality plane manufacture and great value.
