The Shinwa saw guide with adjustable angle can be used with any hand-held circular saw. The Guide is adjustable for cuts from 16° to 165°. The stainless steel protractor has black graduations on a white background for improved readability making accurate setting easy. The guide rule is a strong aluminium extrusion with a stainless steel edge and plastic protective end caps. The locking screw to fix the angle is made of steel with a large brass nut. To help tighten and secure the nut it features a foldable, aluminum handle. The attention to detail attests to the quality of the guide. Rubber stops on the bottom of the hand rest prevent the guide slipping in use. The guide has a groove along its edge for the optional Slider which helps keep your saw securely on track.
Maximum cutting width at 90° is 600mm.
Cut any angle from 16° to 165° with a hand held circular saw
