For the honing and polishing of the inside of turning gouges, woodcarving gouges and V-parting tools, Tormek have developed a profiled leather honing wheel, made of solid tanned leather. The diameter of the larger wheel is 120 mm (4 3/4"), which speeds up the honing process. The sharp profile for V-parting tools is specially treated for optimum function and life. This wheel has exchangeable leather discs so you can easily replace a disc with a worn tip. Discs with alternative, narrower profiles are available as optional extra. The two standard discs have a radius of 3 mm (1/8") and a 60° tip. You can mount double LA-120 wheels, one with standard profiles and one with set of narrow discs, and thus have access to four various profiles at the same time. The design has a large, deep space between the two profiles and therefore permits inside honing of tools with wide and deep profiles and small turning gouges.
Made of solid tanned leather
Two standard discs have a radius of 3 mm (1/8") and a 60° tip
