A relatively simple jig that allows both bevels of an axe head to be ground at exactly the same angle over the full length of the edge (maximum head size 165mm). A nice solution to a problem often encountered when grinding by hand. You can of course, if you choose, have different bevel angles on each side by simply adjusting the height of the support - this is the sort of control that you can only get with a Tormek.
Allows both axe bevels to be ground at exactly the same angle
Adjustable height for different angles if required
