Trend Door Stand
109650
From £70.98 £59.15
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Secures doors vertically and horizontally
  • Makes fitting doors easier, faster and safer
  • Holds doors steady and stable
  • For doors 32mm to 55mm thick
Fitting doors always requires a second pair of hands. If you are working alone then the Trend Door Stand will be your best friend. Whether routing hinge recesses, drilling and chiselling for locks or planing the edge, the Trend Door Stand provides solid support. It makes the process of fitting doors easier, faster and safer. The Trend Door Stand holds everything steady and stable allowing you to carry out the necessary work.
The door is held securely by a screw clamp, which is welded to the 630mm long stabilising bar. The clamp will take doors from 32mm to 55mm thick. The clamp foot has a thick rubber face to prevent damage to the door’s surface.
Note the stand is useful when working thinner sheet material, in which case simply add an offcut as a packer in the clamp.
When you have finished working on the edge, it’s easy to pivot the door upright and offer it up to the door frame without removing the clamp. Maximum door weight 58kg.
The Trend Door Stand is destined to become one of those tools you wish you had bought years ago.
