TSO MTR-X Multifunction Precision Triangle Set
109743
From £309.98 £258.32
Low Stock
  • Pre-set precise angles between 0.90°
  • CNC machined, anodised finish with etched markings
  • 5 x 20mm dog holes for attaching to 20mm grid system
  • Attach to guide rail as a an angle guide
  • Add reference pins and use as a square
  • Attach the clamping angles and use for accurate assembly
  • Use to check and calibrate machine fences
The MTR-X is a very precise triangle with an angle setter, that is used as a protractor or a variable angle fence for setting, laying out, calibrating tools or to aid assembly. Use on its own or attach directly to a Festool, Makita, Kreg or Milwaukee guide rail or utilise the 20mm dog holes for use on a grid system bench top.
Measuring 246mm x 346mm the MTR-X is CNC-precision machined from cast aluminium with an anodised finish for durability that gives a non-marring finish. The graduations are laser engraved on both sides, making the scale easier to read even in poor light. The very precise angle setter allows you to set with a positive lock, any angles between 0-90°. There are 5 x 20mm dog holes drilled into the triangle and it is supplied with 2 dogs to allow the MTR-X to be attached to a Festool MTF or similar grid system and used as a fence. Also supplied are Edge Index Pins that can be attached to the face of the triangle as a reference shoulder, so you can use it as a square.
Clamping angles are also included so that you can attach the triangle with clamps to help assemble your project. Attach to a Festool, Makita, Kreg, Milwaukee or similar guide rail supplied with the adaptor and the triangle turns into a very accurate angle guide, the low profile locking knobs mean that these do not interfere with a track saw when cutting. Calibrating tools is also another feature due to it's compact size. Ideal for tasks such as a fence squaring or setting mitre saw angles or a mitre gauge.
Made in the USA and verified square with automated CMM to .001' along with full length.
Supplied with: 2 x TSO Chamfer close fit dogs, guide rail connector (for Festool, Makita, Milwaukee and Kreg) 2 x M6 short index pins, 2 x M6 long index pins, 2 x 125mm clamping angles and foam systainer insert.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
