UJK Clamp Stand (Pkt 4)
- Support your clamps
- Take the stress out of glue-up and clamping
- Stands attach to Parf anchor dogs or screw onto a board
Axminster Professional HD Parallel Jaw Clamp Pivot 1,000 x 95mmSpecial Price £47.18 £39.32 was £58.98 £49.15 Save £11.80 £9.83
UJK Clamp Stands support parallel clamps and make glue-up faster, easier and less stressful. The slots in the UJK Clamp Stands keep your parallel clamps upright and aligned while you position your workpiece and put the pressure on. These simple, yet effective, clamp supports act like a second pair of hands, and speed up the clamping process.
The stands have a central hole, which can be used to attach them to a Parf anchor dog with an M8 bolt, for use on a multifunction workbench (four M8 bolts are included). Alternatively the stands have holes at each corner for screwing onto a board or bench top.
Each stand is 60mm square and 86mm tall. The slots are 9mm wide, with one 64mm and the other 35mm deep, allowing clamps to cross at 90°.
