UJK Loose Tenon Router Cutters - 1/2" Shank
From £49.98 £41.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Make your own Festool Domino-style biscuits
  • British made UJK Loose Tenon Cutter
  • Suitable for softwood or hardwood
  • Available in 1/2" and 12mm shank sizes, with three cutter sizes each covering 3-4 biscuit sizes, covering all sizes of Festool Dominos
  • Cut any length biscuit
  • Xylan coated minimising friction and resin build-up and enhances chip flow
  • Manufactured from EN8 Steel for strength and durability
The UJK Loose Tenon Cutters, is a game-changer for woodworkers. This innovative router cutter allows you to cut Domino-style biscuits, offering unparalleled flexibility and creativity in your projects.
Craft perfectly fitting Domino-style biscuits from any wood type to either match or contrast with your project. You can use hardwood, softwood, or even off-cuts from your workshop, including wood suitable for outdoor use.
Available in both 1/2" and 12mm shank sizes, with two different cutter sizes, the smaller of the two makes 4, 5, 6 and 8mm biscuits, the larger makes 10, 12, 14mm biscuits, and there’s the flexibility to cut any length you wish using both cutters. The three cutters covers all sizes of Festool Dominos, saving you money on buying packs of Dominos or multiple tenon cutters.
As the UJK Router Cutter range grows, all UJK cutters are proudly made in Britain. Manufactured from EN8 steel and coated with Xylan to reduce friction, prevent build-up, and extend the cutters lifespan. These strong, durable cutters feature a reinforced shank radius, enhancing their strength further for tough tasks.
Designed specifically for use with router tables, the UJK Loose Tenon Cutter are ideal for both professional and hobbyist woodworkers.
Upgrade your woodworking toolkit with the UJK Loose Tenon Cutter and enjoy the freedom to create custom Domino-style biscuits from any wood you choose. This high-quality, British-made tool is a must-have for anyone serious about joinery.
British Made British Made
