UJK Pocket Hole Drill Bit Complete Package
111918
New
From £44.98 £37.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Package includes UJK Pocket Hole Drill with a 12mm Bit, a Stop Collar, and three replacement Drill Tips (30mm, 22mm, and 12mm)
  • Pocket Hole Drill with interchangeable pilot drill tips
  • No need to buy a new drill if the tips snaps
  • Change pilot drill tip sizes quickly
  • Replacement M2 Steel drill tips included in 30mm, 22mm, and 12mm lengths
  • Compatible with all pocket hole jigs
  • Includes drift pin for easy pilot drill tip removal
  • Unique geometry suitable for wider joints
  • Parabolic flute design for rapid waste clearance, ensuring fast, clean results
  • Sharp, precise spurs for the cleanest of cuts
  • •Festool Centrotec compatible for seamless integration
  • Designed for precision and durability, making it essential for strong, hidden joints
  • Show More
Introducing the UJK Pocket Hole Drill Bit Complete Package – your ultimate solution for precise and efficient pocket hole drilling. This comprehensive package includes the UJK Pocket Hole Drill with a 12mm Bit with drift pin, the UJK Stop Collar for Pocket Hole Drill Bit, and three replacement Drill Tips in sizes 30mm, 22mm, and 12mm. The UJK Pocket Hole Drill with a 12mm bit is the ideal upgrade for pocket hole drilling.
UJK Pocket Hole Drill with 12mm Bit
The UJK Pocket Hole Drill with 12mm bit is the ideal upgrade for pocket hole drilling. The key feature of the UJK stepped drill bit is its interchangeable pilot drill tips, no need to buy a a new drill when the tips snap (as they do), with this drill you can quickly change the pilot drill tips using the including drift pin, unlike standard drills.
The replacement drill tips are available in additional lengths of 30mm, 22mm, and 12mm and manufactured from M2 Steel. This versatility allows you to tackle a variety of applications with ease.
Its unique geometry makes it suitable for wider joints, and the UJK Pocket Hole Drill is built to withstand frequent use, providing a better fit for stronger connections. The parabolic flute design rapidly clears waste from your pocket hole jig and with precision spurs allowing for the cleanest of cuts, ideal for creating the perfect plug. All this combining the benefits of high performance and design for fast, clean results.
The UJK Pocket Hole Drill is a testament to high-quality engineering and is designed to deliver precision and durability, making it an essential tool for creating strong, hidden joints. The UJK Pocket Hole Drill is compatible with all makes of pocket hole jigs, including the UJK Pocket Hole Jig, and it is Festool Centrotec compatible, ensuring seamless integration with your existing systems.
We strongly encourage the use of dust extraction when using Pocket Hole Jigs and accessories.
UJK Stop collar for Pocket Hole Drill Bit
This split stop collar is designed to fit the shank of the UJK pocket hole drill bit, as well as other drill bits with 9.5mm (3/8") shanks. Its one-piece single split design provides greater clamping force compared to a set-screw shaft collar. Unlike a locking grub screw type, a split collar grips the shaft without leaving score marks.
Internal diameter: 9.5mm, external diameter: 19mm, thickness: 9.5mm.
