Veritas 3 Piece Miniature Chisel Set
- Blades made from Veritas’s own unique PM-V11 steel
- 1/3 of the scale, approximately 80mm overall
- Blades hardened to HRC 61-63 and ground flat on the face
Don’t let the size fool you. These are fully working, high quality tools even to the point of the blades made from Veritas’s own unique PM-V11 steel. They are about 1/3 of the scale of the Veritas bench chisels. Each one is only about 80mm long overall. The three tools in the set have 3/8"(9.5mm), 1/4"(6.3mm) and 1/8"(3.2mm) wide blades. All permit a delicate touch for fine, controlled cuts, such as box making. Their 3/32"(2.4mm) thick PM-V11 steel blades are hardened to HRC 61-63 and ground flat on the face. They have a 25° bevel. The chisel handles are hardwood with a stainless-steel ferrule. Made in Canada
EAN Barcode | 722356015476 |
