From £145.98 £121.65
In Stock
  • Most versatile Veritas honing guide set
  • Highly useful sharpening aid in any workshop
  • 5 piece set includes standard and narrow blade clamping heads
Customers Also Bought
What's included in the Veritas Deluxe Mk.II Honing Guide set?
Standard Clamping Head
For large projects, the generous precision ground cast iron table plus sliding table (supplied as standard!) provides ample of work surface. For smaller jobs, there is the option of the mitre fence in its T slot groove machined into the table to give even more support.
Narrow Clamping Head
The narrow-blade head clamps blades from the sides with parallel jaws to ensure they stay square to the jig. The jaws are also canted to keep blades centered and tight to the reference face of the jig, whether they have bevelled or square edges – it will even hold chisels that are triangular in cross section. It accepts blades from 1/8" to 1-1/2" wide, holding bevel-edged chisels up to 15/32" thick and square-edged blades up to 11/32" thick. It hones bevel angles from 15° to 40° and back bevels from 10° to 20°.
Straight and Camber Roller
The interchangeable rollers attach to the clamping heads with a single thumbscrew. The eccentric axle mount lets you add a micro-bevel to any angle setting with a simple turn of a knob. The straight roller hones straight edges. At 2" wide, it provides a stable base for even the narrowest of blades. The barrel-shaped camber roller lets you rock the guide slightly to hone a slight curve or camber into a blade edge, eliminating blade tracks when planing.
Angle Registration Jig
Offering an impressive range of angle settings, the integral blade angle registration jig squares the blade and sets the bevel angle in one easy step. A scale and sighting mark help center blades when using the standard head; the narrow-blade head is self-centering. Once the blade is clamped, the jig slides off the guide.
The most versatile Veritas honing guide set to date. This 5 piece deluxe honing guide set includes both the standard and narrow blade clamping heads, as well as the angle registration jig, straight roller base and camber roller base. Combined the heads accept blades ranging from 3mm(1/8") to 72mm(2.7/8") wide. The bases offer the options of straight or slightly cambered edges on your blades. The completely predicable results this set offers for a wide variety of blades makes it one of the most useful sharpening aids in the workshop of anyone who works with hand tools.
  • Angle registration jig, straight roller and camber roller bases
  • Combined heads accept blades from 3mm(1/8") to 72mm(2.7/8") wide
  • Bases offer option of straight or slightly cambered edges
    4.90 56
