Viking Arm Precision Lifting Tool
- Universal tool for precise lifting, clamping, and assembly
- Achieve tasks single-handedly that would otherwise be impossible
- Impressive lifting capacity of 150kg
Viking Arm Base PadSpecial Price ÂŁ14.96 ÂŁ12.47 was ÂŁ21.38 ÂŁ17.82 Save ÂŁ6.42 ÂŁ5.35
Viking Arm Lifting PadSpecial Price ÂŁ14.96 ÂŁ12.47 was ÂŁ21.38 ÂŁ17.82 Save ÂŁ6.42 ÂŁ5.35
Viking Arm Cabinet Installation KitSpecial Price ÂŁ50.74 ÂŁ42.28 was ÂŁ72.48 ÂŁ60.40 Save ÂŁ21.74 ÂŁ18.12
Viking Arm Baseplate & Bars (6 mm)Special Price ÂŁ22.39 ÂŁ18.66 was ÂŁ31.98 ÂŁ26.65 Save ÂŁ9.59 ÂŁ7.99
The Viking Arm Precision Lifting Tool enables you to single-handedly perform tasks that wouldn’t otherwise be possible. Safely and precisely lift items weighing up to 150kg with the patent-pending lifting technology. The innovative mechanism allows a full release as well as controlled incremental lowering, perfect for applications which require a gentler touch. The Viking Arm can also be used in reverse mode as a clamping tool.
The lift capacity is 150kg and range is 7mm-215mm. The applications for use are virtually unlimited: door and window installation, cabinet and kitchen applications, construction of porches, decks, and flooring, as well as machinery installation and levelling. With a one-handed operation, the Viking Arm can raise the work area and hold in place while you work away, reducing the need for numerous tools - perfect for both trade and DIY.
Made in Norway and extensively tested, the Viking Arm is of sturdy construction and made from high-quality components, comprising stainless steel, hardened carbon steel and aluminium. With a range of innovative accessories available, there are even more options to use the Viking Arm for kitchen installation, precise work and more.
