Woodcut Tools Bowlsaver Max 4
- Produce up to 4 bowls from a single blank
- Core bowl from 75mm to 430mm diameter
- Blades with tough, long lasting Stellite tips
- 510mm long handle with foam grip for control
Turning a bowl from a large blank presents the turner with some interesting issues. Not least the amount of useful timber wasted in the form of shavings when hollowing the interior.
The Woodcut Tools Bowlsaver Max 4 enables you to produce more than just one bowl from a single large blank. The Woodcut Tools Bowlsaver Max 4, comes with 3 blades. Thus from a single blank you have the potential to create up to four bowls, hence the name; Max 4.
What may at first sight look complicated is in fact quite simple to use. The unique design offers easy adjustment in order to core a range of bowl shapes and sizes. With the Woodcut Tools Bowlsaver Max 4 you can core bowls from 75mm up to 430mm diameter.
The main platform is cast and precision machined anodised aluminium and steel. It is designed to successfully cope with the pressures of the coring process whether small or large, bowls, wet or dry wood. A suitable tool post to fit your lathe is required for the platform.
The Max 4 comes with a 2MT Tailstock mount, which provides additional stability. A 3/8"x 405mm threaded rod is supplied as a drawbar to provide integrated extra support and stability from the tailstock.
The blades are Stellite tipped. Stellite has great wear and shock resistance. Stellite is used to tip large industrial bandsaw blades, proven to be long lasting and hard wearing. The tips are easily sharpened with a diamond hone.
The large knife has additional support from a machined steel post and a bearing in order to minimise movement especially when coring hard, dense wood.
The 510mm long steel handle with a foam grip offers maximum control. The end of the handle features a spigot to fit an additional handle if further leverage is required.
The Woodcut Tools Bowlsaver Max 4 includes everything you need to start coring bowls from 75mm up to 430mm in diameter. It comes with a detailed guide and ready to use, planning templates to successfully core a nest of bowls straight away.
All packed in a large foam lined box, providing convenient storage when not in use.
Dimensions (approximate)
Base platform footprint: 248mm long (measured from the front edge of the base plate to tailstock assembly x 210mm wide
Weight: 9kg
Operating requirements: minimum 1.5kW flatbed lathe with 405mm to 635mm swing.
N.B. You will need to choose the correct diameter tool post to suit your lathe from those listed (sold separately).
- Large main platform main provides solid support
- 2MT Tailstock mount with drawbar for additional stability
- Easy to follow user guide with planning templates
- Tool post to fit lathe required (available separately)
