WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)
502477
Special Price £24.98 £20.82 was £29.98 £24.98 Save £5.00 £4.17
75 Reviews
In Stock - Ready to dispatch
  • Top quality zinc plated wood screws with a self countersinking head
  • They have deep sharp threads that cut into the wood, not forcing through
  • Penetrating tip that requires no pilot hole or pre-drilling
  • Heat treated to ensure they are hard and resistant to snapping
  • For use in soft or hard wood, MDF or chipboard
  • Torx heads and wax lubricated for the easiest driving, pack of 1,500
The features that set WoodSpur apart...
Gold zinc plated steel finish screws with high resistance to corrosion. Suitable for interior use
in soft or hard wood, chipboard, OSB or MDF.
The head
Increasing the size of the head where it meets the body makes these screws much stronger. This minimises the risk of the head shearing under the final tightening torque.
The tip
The tip cuts as it penetrates and the initial portion of the thread engages immediately. The sharp point helps when placing the screw and prevents skating.
Pack of the most popular sized zinc plated wood screws with a self countersinking head. They have deep sharp threads that cut into the wood rather than simply forcing their way through and a penetrating tip requiring no pilot hole or pre-drilling. Screws are heat treated to ensure they are hard and resistant to snapping. Lubricated with a wax coating to minimise heat and aid insertion. For use in soft or hard wood, MDF or chipboard. Torx heads for high grip. 1,500 screws in pack. Screws require a Torx Bit for 3.5mm a T15 For 4.0mm and 4.5mm a T20 For 5.0mm a T25.
The case measures: 320mm x 260mm x 55mm.
Pack contains:
3.5 x 16mm x 220
3.5 x 20mm x 220
3.5 x 30mm x 300
4 x 30mm x 300
4 x 40mm x 100
4 x 50mm x 120
5 x 50mm x 100
5 x 60mm x 60
5 x 70mm x 40
5 x 80mm x 40
4.80 75
