Gorilla® Waterproof Patch & Seal Tape
- Instantly stops leaks with a durable, waterproof bond
- Seals holes, cracks, gaps, and tears indoors and outdoors
- Works on plastic, wood, metal, glass, vinyl, PVC, and more
- Long-lasting weatherproof repair solution
Gorilla Waterproof Patch & Seal Tape forms a durable, permanent bond that instantly stops leaks - even underwater. Perfect for sealing holes, cracks, gaps, and tears, it’s designed for both indoor and outdoor use. Compatible with plastic, wood, glass, aluminum, steel, vinyl, PVC, and more. Available in black, clear, or white, with the following size options:
100mm x 3m White
100mm x 2.4m Clear
100mm x 3m Black
Tape Width | 100 mm |
