GripIt Plasterboard Fixings 18mm Undercutting Tool
- Accurately cuts recess to allow Gripit wings to open fully
- Clears obstructions behind board, cuts dot and dab adhesive
- Essential if fixing into double thickness plasterboard
- Easy to use, fits into any power drill
Which colour GripIt do I need?
GripIt provide the perfect fixing for each and every plasterboard installation. Take a look below to find out which colour GripIt your task needs.
25mm GripIt
TVs, boilers, kitchen cupboards and more...
20mm GripIt
Radiators, cabinets, small TVs and more...
18mm GripIt
Mirrors, shelves, bathroom fixtures and more...
15mm GripIt
Curtain rails, blinds, small shelves and more...
How to GripIt?
GripIt’s quick fix design make installations simple!
Drill It
Drill a hole into the plasterboard with the correct size drill bit for your requirement.
Tap It
Push the GripIt fixing into the hole and gently tap until the collar sits against the surface.
Turn It
Using a flat screwdriver, turn the insert 90° clockwise to open up the wings at the back of the fix.
Use positioning shown for correct fixing.
Open the GripIt wings by turning the rotary insert. GripIts are also re-useable: simply turn wing screws to release & remove. All GripIts are sold with the recommended screws.
For specific information on the weight load for each fixing please see our technical data sheet.
Occasionally you may encounter a situation which prevents the wings of the Gripit plasterboard fixing from opening fully. For example, dot and dabbed plasterboard where the fixing point comes too close to a dot or a dab, or when fixing into insulated or double thickness plasterboard.
The Gripit Undercutting tool fits into the chuck of any power drill and precisely cuts the necessary recess for the Gripit wings. It is quick, easy to use and control and ensures your Gripit fixings are as strong and secure as intended.
EAN Barcode | 0700953975287 |
- Standard Delivery* - £1.99
